Today I modeled degergent bottle. It was an excellent object to experience the Shark’s Surface Tools. As usual, I met a lot of inconvenience. Perhaps the plan modeling workflow was not correct. But I did not find another way to do this shape. Here is what I wanted to do.
(88kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
I created the basic form of the object and cut out a hole that must be covered with a concave surface.
To begin with, I experienced a
Tagent Cover Surface tool. I was immediately punished for this idea. It was not the right way. Probably the best way is
Guide Loft Surface .
(95kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
I created the guides, but I ran into the
first problem . I could not connect the curves to the edges of the surface. What is wrong? In any case, it did not work for me.
(93kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Then I used
Explode Curve tool. I got two
Control Point Splines . It was
second problem . The guides were «glued» to the control points, but not to the spline. Converting to
Interpolate Spline would disrupt the shape of the object. Finally I got the cover. But it was not the smooth surface that I expected to see. Of course, blending off edges can be forgotten. It will not work with this geometry.
(108kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
I previewed a lot of videos about modeling of objects like this bottle. Why can I not achieve the desired shape? What am I doing wrong?
By the way, I already finished this bottle. Simply interesting is the opinion of the more experienced.
SFX file is too big- But can be downloaded here:
https://www.dropbox.com/...h1q0fdKxEkN7x-lOTIa?dl=0 Edited by user Thursday, April 26, 2018 10:37:16 AM(UTC)
(107kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked digitalphaser for this useful post.
Maybe I would have done this different like doing a negative on the indentation or do a project curve onto surface to divide it, then make handle hole and put blends on every edge.
Originally Posted by: rockyroad_us Maybe I would have done this different like doing a negative on the indentation or do a project curve onto surface to divide it, then make handle hole and put blends on every edge.
Yes, probably my plan is not optimal. I considered various options. But I still have to somehow connect all the parts.
Besides, I did not understand you very well. :)
Edited by user Thursday, April 26, 2018 9:44:58 AM(UTC)
(79kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
I added the base model. Both models are here:
https://www.dropbox.com/...h1q0fdKxEkN7x-lOTIa?dl=0 digitalphaser attached the following image(s):
Originally Posted by: digitalphaser Maybe you need more control points to smooth things out. I highlighted two areas. I think doing control point splines is not my best approach. I like things to connect.
(203kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: rockyroad_us Maybe you need more control points to smooth things out. I highlighted two areas. I think doing control point splines is not my best approach. I like things to connect.
No. A large number of control points is always a source of problems.
(121kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
maybe move the second point from the line at the front towards the left. It adjusts better.
Of course it will be better. But it will be a different shape. Usually I try to do that I need. Not what Shark offers me. :)
