Dynamic Rotate stroke command after changing rotation center are no Shortcuts available
Thanks: 351 times Was thanked: 255 time(s) in 168 post(s)
When using the special Command Alt + Right Mouse during drawing a line, and setup a new rotating center with Alt + Right Mouse + Ctrl, the Dynamic Rotate is then available when just the right Mouse Button pressed. and all Keyboard shortcuts are blocked until Ctrl pressed again.
