Andrew Gray
#1 Posted : Saturday, July 14, 2018 5:59:33 AM(UTC)
Andrew Gray
Hi All
Just want to check if this is right
if I place a block primitive (or any other type) and set the sizes, I can move the block and still control the parameters but if I copy the block then I cant change the block parameters
assy.vc3 (22kb) downloaded 2 time(s).
#2 Posted : Saturday, July 14, 2018 6:33:36 AM(UTC)
Was thanked: 308 time(s) in 207 post(s)
Have you tried the copy with history? Right click the block somewhere in that list is duplicate with history, does this work for you?
Cheers
Andrew Gray
#3 Posted : Saturday, July 14, 2018 4:20:35 PM(UTC)
Andrew Gray
thanks all good
Andrew
