#1 Posted : Monday, July 16, 2018 1:45:47 PM(UTC)
Evening all,
I have a ply file which has come straight from a scanner. If I load it in Shark or VC it loads something, thinks for a few seconds and then the screen finishing loading. Try and click something and it just gives me windows 'ding' like there is a menu open somewhere. What is it? I've had some ply files loads fine so struggling to see what the issue is.
*edit* the file is 5mb zipped up so it wont upload here or to the bug reporter page.....
Cheers
Edited by user Monday, July 16, 2018 1:50:58 PM(UTC)  | Reason: Not specified
murray
#2 Posted : Monday, July 16, 2018 5:24:34 PM(UTC)
murray
There's a maxim from electronic consumer equipment development and manufacturing that holds that it's always the cheapest equipment that's at fault, even when it's not. This is generally because people buy a vast flat screen TV that's connected to a receiver or amplifier via a "standard" like HDMI or DVI that doesn't work, and it's inconceivable to them that the more expensive device mightn't be compliant. That sort of issue with IGES is the reason that STEP was developed, but the paradigm seems to be changing, now that Apple and Microsoft develop their OSs, people update their devices and yet seem to me to frequently blame software developers that their SW is incompatible with an OS that wasn't released when they bought it. Not a lot of logic in that premise. What SW do the scanner manufacturers guarantee their device's output is compatible with? There's a simple file splitter called hjsplit that you could use to divide the file into uploadable-size chunks.
#3 Posted : Tuesday, July 17, 2018 1:26:39 PM(UTC)
So are you saying that because the type of ply file is listed somewhere that I should be aware of what this software is capable of loading.......?
Neither manual says anything about the ply file in the import section. Hence why I'm asking the question.
So after some more digging, it turns out that there are two types of ply file, should've known. One which looks like image one and the other looks like image two. Image 2 loads and does the 'ding' thing, image 1 loads and displays. (These are meshes)
So when loading the one that 'dings' do we know what is happening?
Managed to load up a dinging ply file as a zip.
It does say that the max file size for upload is 16mb? Hence why I mention that also....
Cheers
Edited by user Tuesday, July 17, 2018 1:29:19 PM(UTC)  | Reason: Not specified
processed.zip (3,333kb) downloaded 4 time(s).
image 1.jpg (165kb) downloaded 0 time(s).
imae 2.jpg (209kb) downloaded 1 time(s).
#4 Posted : Thursday, July 19, 2018 2:40:13 PM(UTC)
One looks to be in ascii and the other binary format. If still an issue, zip and private email me the file.
We should be able to read:
ASCII
BINARY BIG ENDIAN
BINARY Little ENDIAN
#5 Posted : Thursday, July 19, 2018 2:51:29 PM(UTC)
Hi Tim,
I'll try again and check for big and little and send a couple of examples. The zipped file attached to my post is the one that dings, its almost like there is a menu open but the menu is no where to be seen, so you can't do anything.
So the ding I bang on about is the windows os ding.
Cheers
