Thanks: 181 times Was thanked: 159 time(s) in 109 post(s)
When I saved this file, there were no extra parts, the yellow angles, they are from
another file.
The next time I opened the file, the yellow angles were there, the original file
that had the angles, only had 4 of them.
Has this happened to anyone else?
Bracket.sfx
(2,165kb) downloaded 2 time(s). L. Banasky attached the following image(s):
(82kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Its the same when I open it in VC10 Perhaps you had hidden the angles first, later Show All, than they come up. H.
when i had such a problem, it helped to activate "clear undo on save"
(75kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Yes, but ViaCad used to clear the undo when it did a backup save. Is this still the case?
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
