#1 Posted : Wednesday, August 22, 2018 8:19:20 AM(UTC)
Was thanked: 216 time(s) in 149 post(s)
Sometimes i create some auxiliary lines to create some Angular Dimensions. I deleted the layer with the auxiliary lines and all Angular Dimensions which was in a dimenions-layer, was also deleted.
Edit:Maybe this is a feature and no bug because of a relationship between the geometry and the dimensions.
Edited by user Wednesday, August 22, 2018 11:16:59 AM(UTC)  | Reason: Not specified
luk72
#2 Posted : Saturday, August 25, 2018 12:06:59 AM(UTC)
luk72
Hi
the angular dimension depends on the line, the linear dimension depends on the points. removing the line removes the angular dimension.
Enjoy
Angular Dimensions will be deleted when a auxiliary line deleted.mp4.mp4 (742kb) downloaded 9 time(s).
mitchb
#3 Posted : Saturday, August 25, 2018 2:24:07 PM(UTC)
mitchb
Don't delete the line, just hide it.
#4 Posted : Sunday, August 26, 2018 3:16:26 AM(UTC)
Hiding is really a good idea, i never used the hiding feature. I changed the color of the layer to a invisible color.
