Was thanked: 47 time(s) in 23 post(s)
I have a suggestion which seems very simple and useful, yet I haven't seen in in any CAD software so far!?!
A lot of parts, products and features are symmetrical in 2 planes. To create them, you always have to mirror twice. I think there should be a command that let's you do such a "quadrant mirror" in one simple step, instead of two.
Have a nice day
cad'n'stuff attached the following image(s):
(27kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked cad'n'stuff for this useful post.
Mirroring twice is rotating 180 degrees.....
mirroring is not the same as rotating. Rotating works great if x=y, but otherwise rotating gives a different result than mirroring. I just think,that a quadrant mirroring option would quicken the workflow of a lot of people
Mirroring *twice* creates the same result as a single rotation, the centre of rotation is the intersection of the mirror lines. My assertion that it's 180° isn't always true though, it's twice the included angle between the mirror lines.
Thanks: 8 times Was thanked: 77 time(s) in 39 post(s)
Polar Duplicate will do what you want.
mitchb attached the following image(s):
(177kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
unfortunately polar dupliccate doesn't work in most cases. I guess I have given the wrong example in the first post. Here are two more examples...
(24kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
I wonder if it's a bug in there, as you can select two planes to mirror about but it only mirrors in one direction.
