Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
When I export an object from Shark to Illustrator format it becomes triangulated facets.
Is there a way to have it exported as faces (sides) so I can change fill colors in Illustrator?
Also is there an option to export as .SVG that I don't know about?
Here's a quick example showing what I see.
Edited by user Wednesday, October 17, 2018 11:23:31 AM(UTC)
(124kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Hello Svg export is not in V10. Did you try eps export from Shark? Regards Jason
Or try DWG format version 2000 and older Regards Jason
Originally Posted by: jdi000 Hello Svg export is not in V10. Did you try eps export from Shark? Regards Jason
Just did and it works! Thanks!!
