Solid Modeling
solid skin-match vertices (#3723)
Hello Tim,
There is a bug with the option to maintain vertical (match vertices) in the solid skin tool.
http://screencast.com/t/Rps5xtE2Jxv Thank you
Antoine
solidskin.sfx
(474kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
hello tim? I'd like an answer to my question please. thank you Antoine
Hello Antoine The match vertices option turns on/off the ACIS vertex matching algorithm which ensures that all profiles consist of the same number of edges. Profile edges are then internally split where additional vertices are needed. This does not have to do with maintaining a vertical slope. I believe what you are seeing is the skinning algorithm blending between different profile heights. I suspect you are wanting a sweep vs skin behavior. Regards Tim
Solid Modeling
