Thanks: 46 times Was thanked: 319 time(s) in 212 post(s)
Trying out the OBJ colour import feature, leaves a bit to be desired to be honest. I scanned this glue gun just to try it out, so it's not the best scan, but you can certainly tell the difference between opening it in mesh mixer and ViaCAD. ViaCAD is blurry and horrible, mesh mixer is not. The same file is loaded in each program. The same number of faces load, the same texture file everything....
(82kb) downloaded 15 time(s). You cannot view/download attachments. Try to login or register.
