help please,
following this video on making a draw view,
https://www.youtube.com/watch?v=S1FtP58etiw I could not repeat, when i move draw view over it is empty??
Also noticed i did not have the layer to pick on mine also!
using pro 10 with the latest update.
thanks for any help,
Steve
Hi
I cannot get this to work in Shark Pro 10 Build 1371 or build 1373 i have never used this before
Brian
Edited by user Wednesday, November 28, 2018 5:55:42 AM(UTC)
Hello Steve
When you first activate single draw view tool. You can choose which type in the drop down at the top. The layer view or the original draw view. The layer view behaves like the video, the older draw view objects have to be copied and pasted into the view. The key to the layer view is you need to drag a window over the geometry when you first activate the tool.
Also once you create a draw sometime yo need to zoom or pan to get the geometry where you want it.
(58kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
JASON, That was what I was missing, thank you! Steve
