17b
#1 Posted : Wednesday, December 5, 2018 3:08:53 PM(UTC)
17b
if making a polygon exclusive with straight lines, i get sharp angles after joining all curves. Exchanging one single line with a spline, creates weird radii instead of the sharp edges from before. These radii can be manipulated by using the tolerance variable, but it cant be set to off.
How can i get rid of this?
Best regards
Stefan
Edited by user Wednesday, December 5, 2018 3:11:44 PM(UTC)  | Reason: Typos
17b attached the following image(s):
rockyroad_us
#2 Posted : Wednesday, December 5, 2018 7:22:55 PM(UTC)
rockyroad_us
You need to break the polygon if it is a smart polygon. If converted to line or done with lines instead of smart polygon, then you can use a fillet to round the corners. Converting the polygonal to a spline gives that result as it uses an algorithm to blend the lines of the polygonal. It is just an approximation that it does. Two lines don't define a spline so it kinks it at the corner to make one continuous spline.
17b
#3 Posted : Monday, December 10, 2018 4:22:13 PM(UTC)
17b
You are my hero! Ive got it working.
Thanks!!!
