Is the smart licensing no longer a part of SharkCAD?
Thanks: 323 times Was thanked: 197 time(s) in 138 post(s)
On the new Punch website i can read nothing about.
The licensing has not changed on the SharkCAD products. What are you referring to when it comes to the "Smart" Licensing.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
Originally Posted by: Todd Quinlan What are you referring to when it comes to the "Smart" Licensing.
Sorry, my english is bad and i don't know what you mean with "referring to when it comes". You have forget to tell us about the smart licensing here:
https://www.punchcad.com...pro-v10-download-windows And where is the link to the forums on the website? Is this the final version?
And why is the product Matrix
https://www.punchcad.com/punchcad-product-matrix a top secret link because not found on the new website?
Edited by user Wednesday, January 16, 2019 9:58:36 AM(UTC)
Thanks: 185 times Was thanked: 159 time(s) in 109 post(s)
I think maybe the "Smart" licensing refers to Shark products being able to be installed on more than 1 computer, but not being used on more than 1 at the same time. ViaCad products can only be installed on 1 computer, period. Larry
Originally Posted by: MPSchmied And why is the product Matrix a top secret link because not found on the new website?
at the bottom (left side):
"Compare
Punch!CAD Versions "
Originally Posted by: L. Banasky I think maybe the "Smart" licensing refers to Shark products being able to be installed on more than 1 computer, but not being used on more than 1 at the same time. ViaCad products can only be installed on 1 computer, period. Larry
yes but this information are not on the new website.
Originally Posted by: posh.de Originally Posted by: MPSchmied And why is the product Matrix a top secret link because not found on the new website?
"Compare
sorry i am blind sometimes. I guess there will be no german version of shark 10. Will there maybe a german version of shark 11? I have no problems with the english version, i use it just for learning english at the same time. :) Viele Grüße und ein gutes neues Jahr.
Originally Posted by: MPSchmied I guess there will be no german version of shark 10. Will there maybe a german version of shark 11?
Customers of us can obtain the German localization of the software (which we do develop amd maintain since 2003) simply by
request (serial no req.). The help system (?-button at tool ribbon) and the documentation (manual & ref. card in help menu) as well as the accompanying stuff (templates, materials, symbols etc.) are currently not included.
ein frohes Neues,
Edited by user Thursday, January 17, 2019 6:03:40 AM(UTC)
See I'm not sure. I have windows 10 and 7 dual boot. Shark 10 installed on windows 7 fine. Tried installing in windows 10 and it's having non of it. Same with version 11. Will not register. Doesn't really matter just tried it and it failed. So stick with windows 7
Originally Posted by: UGMENTALCASE ... Tried installing in windows 10 and it's having non of it. Same with version 11. Will not register.
what exactly does this mean? ...error messages? ...be descriptive!
Well with Shark, I type in all the serial numbers etc, click register and its says something about code isn't correct for version or something, can't quite remember but it's V10 and all the same stuff I use for Windows 7 set up. And with V11, it just throws up a fail to register error. Oh and also the Shark 10 version I have comes with Powerpack, and this doesn't show in the menu either. I'll try and get some screen shots, but I think I uninstalled it all
in general; for registration on a new system or a system with changes of the hardware or operating system, an existent authorization code will not work, i.e. a new authorization code is required.
For doing this, a new product activation can be issued by filling in serial no and registration code to the registration dialog but
not the extistent auth. code, click "Register Now" then:
Powerpack not showing in the menu is
a bug and requires an update to fix ,
Todd Quinlan is able to fix this.
Edited by user Friday, January 18, 2019 6:54:30 AM(UTC)
Yep did all that and it didn't work, and like I say didn't load the powerpack.
