Trimming impossible because of ACIS Error
Thanks: 308 times Was thanked: 186 time(s) in 132 post(s)
Error Message: inconsistent face-body relationships: Trim Solid_2155
Is working wit SharkCAD possible? Sometimes i doubt.
(120kb) downloaded 19 time(s). You cannot view/download attachments. Try to login or register.
It is better to use no curve for trimming, It worked good with a infinite plane. maybe the curve was not long enough, but this gurve was long enough.....
Using a curve or a simple line is depending from the sight angle on to the bench and object. That may cause impossible cuts.
Using the Infinite Plane is aligned only to its coordinates and perpendicular to its plane.
horst.w
GER
(112kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Same Trim but Top-View:
H.
(73kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked horst.w for this useful post.
Originally Posted by: horst.w Same Trim but Top-View: H.
Yes, thank you. My fault, i setted the wrong option "perp to view" But the right Option is "Specify Vector" Then you have to set 2 points fpr sweep direction. But maybe is just cutting in the top view easier than creating a "infinite plane" and "select 2 points for sweep direction".
(6kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
