#1 Posted : Friday, February 8, 2019 10:12:37 AM(UTC)
Was thanked: 197 time(s) in 138 post(s)
Error Message: inconsistent face-body relationships: Trim Solid_2155
Is working wit SharkCAD possible? Sometimes i doubt.
#2 Posted : Friday, February 8, 2019 10:17:57 AM(UTC)
It is better to use no curve for trimming, It worked good with a infinite plane. maybe the curve was not long enough, but this gurve was long enough.....
horst.w
#3 Posted : Saturday, February 9, 2019 2:20:36 AM(UTC)
horst.w
Using a curve or a simple line is depending from the sight angle on to the bench and object. That may cause impossible cuts.
Using the Infinite Plane is aligned only to its coordinates and perpendicular to its plane.
horst.w
GER
horst.w
#4 Posted : Saturday, February 9, 2019 2:29:53 AM(UTC)
horst.w
Same Trim but Top-View:
H.
thanks 1 user thanked horst.w for this useful post.
MPSchmied on 2/9/2019(UTC)
#5 Posted : Saturday, February 9, 2019 6:20:15 AM(UTC)
H.
Yes, thank you. My fault, i setted the wrong option "perp to view" But the right Option is "Specify Vector" Then you have to set 2 points fpr sweep direction. But maybe is just cutting in the top view easier than creating a "infinite plane" and "select 2 points for sweep direction".
