la mouche
#1 Posted : Tuesday, January 25, 2011 4:23:50 AM(UTC)
la mouche
Hello Tim,
you offer us the tool hole and screw symbols. (french only?)
Can you offer us, now, a [COLOR="Lime"]real[/COLOR] placement function [COLOR="lime"]pro parametric[/COLOR] type (mechanical) of these screws?
for example using the hole axis and only the bearing surface of the screw, or ... the origin of the symbol as a reference.
Imagine ....: a metal with [COLOR="lime"]many[/COLOR] holes ... hmm? :)
Please.
http://screencast.com/t/bQnEE4YF2
Antoine
Capture d™©cran 2011-01-25 11.12.03.png (26kb) downloaded 4 time(s).
#2 Posted : Wednesday, January 26, 2011 12:24:22 PM(UTC)
Where did you get the screw symbols?
please, i really need them
Luis G.
MacOSX Ventura 13.6.4
Jean-Francois Jacques
#3 Posted : Wednesday, January 26, 2011 12:50:57 PM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
In your build 929 (not in 959) through Concept Explorer
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#4 Posted : Wednesday, January 26, 2011 2:48:49 PM(UTC)
I got that library, but all the 3d screw and nuts are placed as a group of curves and lines, not solid
Luis G.
#5 Posted : Thursday, January 27, 2011 9:47:48 AM(UTC)
Canada
You're right! Why? I have no answer!
When I need a fastener, I go to http://www.mcmaster.com/ and I download the 3D SAT file. Every time it's perfect!
#6 Posted : Thursday, January 27, 2011 10:18:32 AM(UTC)
Hi Antoine
Have you tried the Assembly Insert tool?
la mouche
#7 Posted : Thursday, January 27, 2011 10:29:42 AM(UTC)
la mouche
hello Tim,
yes i'm try, but....it is verrrrry long and not productive for my opinion.
1,2,3,4,5 clics for each screws!!!!!!
it's ok for simple and no more pieces, but in the case with ...40X screws, that's a hell.:cool:
Antoine
#8 Posted : Sunday, January 30, 2011 11:19:40 PM(UTC)
I do the same, download from mcmaster or 3dcontencentral each time I need some, but is slow process and we should have a descent library for this parts, not mentioning some parametric function for it.
Hi Antoine
Tim, any answer about the 3d library?
Luis G.
la mouche
#9 Posted : Tuesday, February 1, 2011 2:52:04 AM(UTC)
la mouche
the 3d srews library is a French development. :rolleyes:
the ideal would be to make parametric!
who can? :eek: [COLOR="Red"]with the new tools of constraints[/COLOR]
Antoine
Guest (5)
