Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
I am not able to figure out how to use and how to create threads in ViaCad pro v11 with Power Pack....any help will be helpfull
Thanks: 47 times Was thanked: 336 time(s) in 223 post(s)
Hi, put a hole in as normal. Go powerpack, modify, thread. Select internal/external. Change pitch and length. I think you need to select the face for threading and holes centre.
UGMENTALCASE: Thank You...it did work as you did explained. ....go to....powerpack>modefy>thread.....select what needed...internal or external thread in menu...Select face on part, than click middle of the hole ( internal ) or middel of the sylinder ( external ).
dreiernfres attached the following image(s):
(17kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked dreiernfres for this useful post.
