#1 Posted : Thursday, July 4, 2019 7:39:12 AM(UTC)
I was testing Shark LT 8 and did not find out where the config files stored. The config will be not saved in the Folder: C:\Users\%Username%\AppData\Local\Punch!\ But the config will be saved anywhere and i didn't find anything in the registry.
Edited by user Thursday, July 4, 2019 1:58:14 PM(UTC)  | Reason: Not specified
posh.de
#2 Posted : Friday, July 5, 2019 6:48:27 AM(UTC)
posh.de
you do have already a SLT v9 license?
see:
Code:
C:\Program Files (x86)\Punch! Shark LT 8.0...\Environ\
#3 Posted : Saturday, July 6, 2019 6:50:03 AM(UTC)
Thank you very much, i will watch the config folder and testing my shark 10 config. I got my licenses by posh.de. I do not need the shark 8 license because i use it at time only for testing. Shark 8 is only 32 bit, but i guess, this have nothing to say. If i find out shark 8 is better than 9 and 10 and 11 i will watch for a license downgrade.
Edited by user Saturday, July 6, 2019 6:53:31 AM(UTC)  | Reason: Not specified
#4 Posted : Saturday, July 6, 2019 7:09:02 AM(UTC)
Code:
No, this is wrong. Please watch my screenshot, there are only old files, but i changed the config, there have to be new files if it contain used config files.
Edit: First Test result: The Cutlist Bug with the false Cutlist Partnames are completely fixed in Shark 8. In Shark 9 will be the features renamed and in shark 10-11 is it impossible to get a good cutlist with right names without removing the complete history before. Watch my second screenshot for the proof.
Edited by user Sunday, July 7, 2019 11:20:01 AM(UTC)  | Reason: Not specified
posh.de
#5 Posted : Monday, July 8, 2019 7:07:19 AM(UTC)
posh.de
...i changed the config, there have to be new files if it contain used config files.
for the recent ones see:
Code:
C:\Users\<Username>\AppData\Local\Punch!\SharkLT\
Edited by user Monday, July 8, 2019 7:08:09 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, July 8, 2019 7:41:47 AM(UTC)
It is true, Shark LT 8 don't touch the config in "....AppData\Local\Punch!\SharkLT\" But i guess i have finished my testing. Shark 8 is in some cases slower than shark 9 and the MTS for tubes works again in shark 9 because of a miracle.
