sainttimothy
#1 Posted : Thursday, December 12, 2019 10:38:07 AM(UTC)
sainttimothy
Anyone here do training? I'm struggling with primitives. I'm struggling with push/pull. I could go on.
I need to design square and rectangular tubing frames. The best function I've found is primitives. But I'm open to any way that is less painful.
Some of the issues I have are:
block primitive 3 point diagonals- it doesn't usually place the block at the point I chose. When I type a number, the part extrudes often in the negative direction. But not always.
Screen share and/or phone?
Timothy
#2 Posted : Thursday, December 12, 2019 11:36:23 AM(UTC)
Hi Timothy
Have you tried the pipe tool? Select centerline and pick either circle or rectangular section and specify wall thickness.
Edited by user Thursday, December 12, 2019 11:54:05 AM(UTC)  | Reason: Not specified
sainttimothy
#3 Posted : Thursday, December 12, 2019 11:54:27 AM(UTC)
sainttimothy
Thanks for the suggestion Tim. But I don't think that's gonna work for me (and I can't find it). I want to use an edge rather than center.
#4 Posted : Friday, December 13, 2019 4:51:58 PM(UTC)
Was thanked: 216 time(s) in 149 post(s)
if you need a cutlist you need to make every single part from the frame also with the miter. For symmetrical parts you can use later the mirror tool. Maybe i make a video how it works, but you need alot tools for this like the extrude tool and some Tools for cutting the miter (place a infinite plane in the right position and split the solid and delete the Sektion.
Edited by user Friday, December 13, 2019 5:22:01 PM(UTC)  | Reason: Not specified
