JerryP
#1 Posted : Tuesday, December 17, 2019 10:03:58 PM(UTC)
JerryP
What Via cad software would be good for plasma cnc ?
The plasma cnc I am getting comes with Fusion 360, and after trying it, I think I hate it.
I think a 2D program would be better and easier
#2 Posted : Wednesday, December 18, 2019 10:58:13 AM(UTC)
Was thanked: 140 time(s) in 107 post(s)
I guess you need a G-Code for your CNC-Machine. Create first a 2D Drawing in 1:1 and convert it to G-Code. Maybe you can use: https://www.cadkas.com/dxf2gcode.php
or you have already a CAM-Software?
L. Banasky
#3 Posted : Wednesday, December 18, 2019 11:16:20 AM(UTC)
L. Banasky
Was thanked: 149 time(s) in 102 post(s)
ViaCAD 2D would work fine. Export as a .dxf r12 into a CAM program, to
generate G-code. I use SheettCAM, very easy to use.
https://www.sheetcam.com/
R-12 dxf.jpg (109kb) downloaded 5 time(s).
MPSchmied on 12/18/2019(UTC)
