Hello,
i like to draw a ring with text around.
The problem is, to find the right size for the text.
I cannot see how the text looks, when i use 'along curve text'
I want the text horizontel to the ring, see picture.not vertikal, what is a little easier to use.
So, first i need to change objekt type, to see what Text along curve did.
After this i have to do all the steps again.
And it is very difficult and/or not possible to change the textsize.
Is there any hint or a walkaround ?
Thank you very much for every help!
Sorry, i forgot; i tried it with ViaCad 10 pro and with SharkCad 12
Edited by user Tuesday, October 27, 2020 11:52:04 AM(UTC)
a.wieneke attached the following image(s):
(111kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
