BillB
#1 Posted : Monday, November 16, 2020 5:56:00 AM(UTC)
BillB
Is anyone else having problems with ViaCad 11 and MAC OS 11 Big Sur?
Bill Bedford
Viacad Pro 11 (11417)
OS X 10.13.6
Joachim
#2 Posted : Tuesday, November 17, 2020 6:07:13 AM(UTC)
Joachim
Hi Bill,
I am running ViaCAD 10 Pro on my MacBook Pro. Yesterday I have upgraded the MacOS from Catalania to Big Sur. I started ViaCAD and my standard settings for background colour etc were lost. Now it’s not possible to change the background to an other colour and also it’s not possible to create any lines, primitives, etc on the worksheet. For example: When I start a line and pull the second point, the black line is visible. After release the mouse button the line disappears. That’s my experience up until now. I’m just searching for further information on the web.
Regards from Germany
Joachim
BillB
#3 Posted : Tuesday, November 17, 2020 6:16:26 AM(UTC)
BillB
I had this reply from Todd Quinlan yesterday:
Quote:
Hi Bill Bedford,
Version 11 of the software is not compatible with Big Sur. You would need to upgrade to V12. The upgrade cost is $149.99USD and you can use the link below to access the proper upgrade.
So it looks as if there is no alternative to upgrading
Bill Bedford
OS X 10.13.6
[email protected]
#4 Posted : Tuesday, November 17, 2020 7:33:35 AM(UTC)
ray.hill4@ntlworld.com
I too am having problems with V11 it doesn't display any of the 2D or 3D primitives, since Big Sur went on. I saw the note about V12 fixing the problem but I am very loath to commit more money to solve a fault on something that mainly worked well before . So I'm inclined to sit on the fence for bit and see how the story pans out. There must have been something in 12 that fixed a known pending problem, I am surprised that a patch wasn't made available at the time for existing V11 users. I am tempted to buy it to play with the animation but since the 10mins of video documentation at time of V11 release is largely worthless I may not bother. There is a nice engine on the box it would be decent if some written documentation was there to walk through at least 15% of that type of thing.
wilsonrj
#5 Posted : Thursday, November 19, 2020 8:21:25 PM(UTC)
wilsonrj
It's been a rocky road to stick with ViaCAD from TurboCAD V2 through V10, (2D up thru 3D) then to ViaCAD Pro 10 and then ViaCAD Pro 11. I've seen fits and starts, some workable and others requiring a payoff upgrade. I'm seeing that the personal use cost isn't worth staying unto date, especially when it has been common, you need a version for the next level of operating system, then just buy our latest and greatest. Thank you for all the customer loyalty.
thanks 1 user thanked wilsonrj for this useful post.
L. Banasky on 11/20/2020(UTC)
a.wieneke
#6 Posted : Tuesday, December 1, 2020 11:45:47 AM(UTC)
a.wieneke
now i have a problem.
since a while, i use sharkcad 12.
When i need a model to sheeet i used ViaCad 10.
because in SharkCad. my version will not show the possibility
(the frame, i have no idea to explain, hope you will understand )
to change the view ( viewproperty ) in the sheet.
so, what can i do now, i upgradet to Big Sur.
And in some tools the ViaCad 10 was more stabil.
viele Grüße
Andreas
http://www.wieneke.biz
SharkCad pro 14
OS X 14.0
PeterPan
#7 Posted : Tuesday, December 8, 2020 4:26:19 AM(UTC)
PeterPan
Same here.
ViaCAD Pro v11 build 1441 on macOS Big Sur 11.0.1 will not display anything, not even the axis. Won't change background colour.
It is disappointing that you need buy an upgrade for fixing an issue instead of the issue being fixed.
Thanks for your post.
thanks 1 user thanked PeterPan for this useful post.
L. Banasky on 12/8/2020(UTC)
Subccowboy
#8 Posted : Sunday, December 13, 2020 1:44:29 PM(UTC)
Subccowboy
I have sharkcad V12 and I cannot get it to work with Big Sur so far (opens but doesn't display any models or lines drawn). I checked and am on the current build of the software and big sir and both are current. Sent email to Punch support today about it, will update when I hear something. But for now it doesn't look like V12 works with big sur.
Edited by user Sunday, December 13, 2020 1:45:05 PM(UTC)  | Reason: Not specified
BillB
#9 Posted : Sunday, December 13, 2020 1:49:38 PM(UTC)
BillB
You need a build later than 1569. You may have to ask support to send you a copy. The latest build in the beta program is 1572, so that would be another way of getting a copy that works on Big Sur.
Bill Bedford
OS X 10.13.6
Subccowboy
#10 Posted : Sunday, December 13, 2020 2:12:19 PM(UTC)
Subccowboy
Thank you! Got back on the Beta list for 1572, up and running now!
dadux
#11 Posted : Friday, December 25, 2020 8:32:48 AM(UTC)
dadux
How can I get ViaCad 11 build 1572?
D
Claus
#12 Posted : Saturday, December 26, 2020 12:58:36 AM(UTC)
Claus
Denmark
You will need to upgrade to V12
D
