la mouche
#1 Posted : Wednesday, January 28, 2009 4:07:43 AM(UTC)
la mouche
Hello,
Do you have a better way to build this volume?
gasp!:eek:
more this! (same problem?)
http://forum.punchcad.com/showthread.php?t=1970
PLease see the attached files.
Thank you.
Antoine
1.sfx.zip (141kb) downloaded 5 time(s).
zumer
#2 Posted : Wednesday, January 28, 2009 7:07:57 AM(UTC)
zumer
Yes, but I have ViaCAD, not Shark. If you post a VC file of your curve primitives, I can see two or more ways of doing it other than rail sweep.
murray
Steve.M
#3 Posted : Wednesday, January 28, 2009 7:13:06 AM(UTC)
Steve.M
murray
Hi murray,
VC will import the shark files, I have just done that to check this problem.
- Steve
Steve.M
#4 Posted : Wednesday, January 28, 2009 7:16:37 AM(UTC)
Steve.M
Hi Antoine,
This result from the 2 rail sweep is very bad. Such basic functions should work correctly, without this, then I cannot trust the application to correctly do any higher functions.
I am just creating a post to better explain my thoughts and findings.
- steve
dexter
#5 Posted : Wednesday, January 28, 2009 7:31:17 AM(UTC)
dexter
I tried it with the Two-Rail Surface, as well, without much luck (in ViaCAD).
la mouche
#6 Posted : Wednesday, January 28, 2009 7:38:25 AM(UTC)
la mouche
Hello,
another way for this problem.
See please the attached files.
3 step.
But...not with the twoo rail sweep, strange.:confused:
Thanks.
Antoine
Steve.M
#7 Posted : Wednesday, January 28, 2009 7:43:12 AM(UTC)
Steve.M
There should be no need to look for workarounds for this. On a 2 rail sweep the profile should retail the tangency to the rails, or at the very least there should be the option to retain tangency.
zumer
#8 Posted : Wednesday, January 28, 2009 7:51:36 AM(UTC)
zumer
2-rail's a bust, but skinning between the two ellipses and thickening the surface created works fine - for this shape.
skin then thicken.jpg (55kb) downloaded 5 time(s).
Steve.M
#9 Posted : Wednesday, January 28, 2009 8:04:26 AM(UTC)
Steve.M
I have just spent the last 15 minutes or so putting together a post to report this bug in the beta section, when I finished and "submit reply" the forum logged me out and deleted the post. Even the forum software is a bit of a joke.
la mouche
#10 Posted : Wednesday, January 28, 2009 8:05:07 AM(UTC)
la mouche
Olala!
Murray, you are, may be, the person for my problem, waiting since ... 2 years.
The solution volume is desperate, you could give me the procedure that the surface?
See please the attached file.
Thank you in advance.
Antoine
test.sfx.zip (7kb) downloaded 5 time(s).
Steve.M
#11 Posted : Wednesday, January 28, 2009 8:52:21 AM(UTC)
Steve.M
2 years :eek: I would personally of dumped the software and moved to a cad system that has basic functions working correctly.
zumer
#12 Posted : Wednesday, January 28, 2009 9:49:04 AM(UTC)
zumer
Antoine, the only part of this file that gives any real pause for thought is the top surface. I drew two closed curves around the inner and outer upper vertices of the vertical profiles and skinned a surface between them. Then thickened that surface. The thickened solid's walls aren't vertical, but you can extrude the curves vertically to trim the solid. Trim the bottom of the solid with the world workplane. Now it's very late and goodnight!
zumer
#13 Posted : Thursday, January 29, 2009 3:19:58 AM(UTC)
zumer
Okay Antoine, here's your shape. The attached file shows how it was made. Two solid ellipses extruded, then the inner one subtracted from the outer. The top surface was made by extending the top lines of the profiles, then drawing inner and outer curves that overlap the body. A net surface made from those two curves, then thickened to solid, which is subtracted from the ellipsoid body. Lots of hoops to jump through, and things don't always work the way you'd expect - which is how we got here from birail sweeps. And bear in mind that VC doesn't have surface booleans, so I've had to take the long way around for some actions.
test1.vc3 (327kb) downloaded 5 time(s).
la mouche
#14 Posted : Tuesday, February 3, 2009 3:34:43 AM(UTC)
la mouche
hello,
thank you for your proposal.
indeed it requires many operation.
I hope the ... will be corrected.
... it works perfectly with .. (cobalt) oops.
Best regards.
Antoine
Guest (5)
