Keith2019
#1 Posted : Wednesday, January 20, 2021 9:59:26 PM(UTC)
Keith2019
I have tried many options to try and unroll a surface to produce a cutting outline for a brass sheet head light for a model steam locomotive, I am making.
I first made a solid model then converted it to a Surface. From the surface I tried using the PowerPack unroll command, but am have virtually no success. I did look at a tutorial on YouTube of Viacad unfold command and could reproduce similar results. Thus I think the PP unfold / unroll command is working, however not on the model I made.
I have attached a picture of the top of the loco head light I am trying to unfold. I ideally need a layout of a side and front. I have also attached a picture of the side of the light, which was converted from the solid model to a surface. I then manually removed sections from the front, back and other side mesh elements. Still I had no luck with unrolling it.
I have also attached a copy of the file I am working with. I am using TCMac Pro V 11 and V12 with the Powerpack.
Any help or guidance would be gratefully appreciated.
Thank you,
Keith
Top Headlight.tcp.zip (1,481kb) downloaded 6 time(s).
Keith2019 attached the following image(s):
Whole Model.jpg (296kb) downloaded 2 time(s).
Side Surface.jpg (142kb) downloaded 2 time(s).
#2 Posted : Thursday, January 21, 2021 5:54:06 AM(UTC)
Convert it to a mesh first. It doesn't work very well with surfaces at all. If it was a ruled surface you would have more luck with it as it has something to progressively unroll.
Attached file converted to a mesh and unrolled. Just select the surface, right click, change object type, select mesh
Top Headlight.sfx (1,568kb) downloaded 7 time(s).
Keith2019 on 1/21/2021(UTC)
Keith2019
#3 Posted : Thursday, January 21, 2021 5:15:47 PM(UTC)
Keith2019
Thank you very much UGMENTALCASE, your guidance and help worked perfect :-)
Also thank you for updating the Top Headlight file.
thanks 1 user thanked Keith2019 for this useful post.
UGMENTALCASE on 1/22/2021(UTC)
