James
#1 Posted : Monday, May 31, 2021 10:56:40 AM(UTC)
James
It's been a long time since I used the forum also punch
I have been sent a drawing dxf but when I open it and check the 1 inch scale box on drawing it's dimention are .38 of a inch how do I get the drawing to the right dimentions
James
rokoko
#2 Posted : Monday, May 31, 2021 11:36:38 AM(UTC)
rokoko
maybe you can scale the whole drawing with the scale/stretch tool. i showed a way to scale an image here: http://forum.punchcad.co...sts&t=9783#post37261 (post #8)
instead of the image you could select all objects in the drawing except the two scaling guide lines
Edited by user Monday, May 31, 2021 11:37:46 AM(UTC)  | Reason: Not specified
thanks 2 users thanked rokoko for this useful post.
MPSchmied on 5/31/2021(UTC), specktech on 6/2/2021(UTC)
#3 Posted : Monday, May 31, 2021 1:55:00 PM(UTC)
change scale button in the utilities toolbar
James
#4 Posted : Tuesday, June 1, 2021 1:51:36 AM(UTC)
James
silly me It's was inches and I imported as mm where I should of imported as inches then changed to mm after import
all sorted now but a big thank you for the help
James
thanks 1 user thanked James for this useful post.
