ErnieD
#1 Posted : Sunday, June 6, 2021 12:37:56 PM(UTC)
ErnieD
Hello ,
As above I developed the solid model in BobCad , saved it as an .iges file and imported into viacad . By the way I am new to via cad and I like the sharp graphics . There are areas on the model where , as I added features some of them protrude through from inside to outside .
Is there a way in viacad for me to easily remove those unwanted features ? If so , can anyone explain in simple terms a step by step way to do this .
Thanks in advance for any help ,
Ernie
#2 Posted : Sunday, June 6, 2021 2:43:37 PM(UTC)
Was thanked: 186 time(s) in 132 post(s)
No. You can improve the rendering resolution to super fine, but you cant remove this effects completely in the working mode. Only High res Photo rendering can remove such side effects.
Edited by user Sunday, June 6, 2021 2:44:23 PM(UTC)  | Reason: Not specified
