svg /dxf exports wrong scale. How do I turn off scaling?
Thanks: 22 times Was thanked: 8 time(s) in 8 post(s)
Hi when I do an export I get it exported to fit 8.5x11 letter- I am frustrated with this as I need full size no scaling exports on dwg, dfx, svg. How can I make exports full size?
Digital has a select pull down for mm, inches and so on. Svg is a funny one. I had loads of problems with it, different dpi settings gave me different scales. Something else they haven't done anything about.....
2 users thanked UGMENTALCASE for this useful post.
Thanks: 320 times Was thanked: 192 time(s) in 136 post(s)
Originally Posted by: jbskaggs How can I make exports full size?
File> Page Layout> Scale> Scale Ratio must be 1
All your Draw views must have the scale 1. Click at the left top of a draw view for properties and change the scale to 1 and "Frame to Extents". For 1:1 Export it is better to use no draw views.
Originally Posted by: UGMENTALCASE Digital has a select pull down for mm, inches and so on. Svg is a funny one. I had loads of problems with it, different dpi settings gave me different scales. Something else they haven't done anything about.....
no idea what this have to do with the topic, but 2 persons thanked for this.... strange.......
Edited by user Thursday, June 17, 2021 3:45:01 AM(UTC)
Originally Posted by: MPSchmied Originally Posted by: jbskaggs How can I make exports full size?
I spent loads of time playing with this.... and even though scale is set to 1:1 and I have tried fit to scale, fit to area, etc I always get a very tiny export.
So if I create a 6" square in top view- set scale in page layout to 1:1 export in svg the resulting SVG is 3.023in in Inkscpe. Though Easel (by inventables a Cam Program) does import it at 3.023in as well.
I did sent model to sheet, frame to extents and it did the same thing.
I also tried a 12" square and it exported 3.446"
Could someone help me? Surly there is a way to fix this? On Shark 12
Edited by user Saturday, June 19, 2021 7:53:40 PM(UTC)
| Reason: updated actions
Originally Posted by: jbskaggs I also tried a 12" square and it exported 3.446"
The SVG-Export works not properly. It seems this is using just the Screen-Scale in a similar way like the PDF-Export or the PNG-Export. But the DXF-Export should working properly.
Edited by user Sunday, June 20, 2021 1:51:26 AM(UTC)
Originally Posted by: MPSchmied Originally Posted by: jbskaggs I also tried a 12" square and it exported 3.446"
Thank you so much! This worked.
