ctkjose
#1 Posted : Friday, March 25, 2022 2:01:58 PM(UTC)
ctkjose
Im trying to understand the "Mesh Parameters" when exporting a shape to STL.
In circular shapes the facets are quite visible (low triangle count/large triangles).
Playing with the options of the "Mesh Parameters" dialog when exporting the STL I have made this observations:
1. Smaller value for Normal Deviation makes the length of the base of the facet triangles smaller.
2. An Edge Length value of other that zero changes the length of each facet triangle.
Question 1: Any suggestion on where I can get info on each of the parameters ("Mesh Parameters") when exporting to STL.
Question 2: Any suggestions on how to get more detail/precision on the STL exports.
ctkjose attached the following image(s):
Screen Shot 2022-03-25 at 4.06.30 PM.png (287kb) downloaded 8 time(s).
#2 Posted : Friday, March 25, 2022 4:07:22 PM(UTC)
It's in the manual I think. I just knock the deviation down to nearer zero. You gain more facets and better shape
ctkjose on 3/25/2022(UTC)
2murray
#3 Posted : Saturday, March 26, 2022 1:27:51 AM(UTC)
2murray
Was thanked: 28 time(s) in 18 post(s)
If you're 3D printing with fused filament printer and slicing with Cura, Cura will slice six formats other than .stl. One or more of those might give you output that pleases you more than .stl.
mitchb
#4 Posted : Saturday, March 26, 2022 10:36:47 PM(UTC)
mitchb
Tim's book, "Tips and Tricks" has the info you want. Find it here:
Masterviacad
MeshParams.pdf (1,400kb) downloaded 13 time(s).
thanks 1 user thanked mitchb for this useful post.
ctkjose on 3/27/2022(UTC)
