SharkCad Pro v12 vs VENTURA
Thanks: 2 times Was thanked: 29 time(s) in 21 post(s)
Using the space bar to move the view is erratic!!! Cannot grip the Gripper!! Like Tim wrote problem with the snaps!
Shark is unusable!
Edited by user Thursday, October 27, 2022 2:55:54 PM(UTC)
Still tracking down a solution to macOS Ventura.... Tim
Yea, my problems so far with ViaCAD pro V12 is funny issues with the mouse, like scrolling to zoom in or out, the part goes way off and will not center, curser does not show up in any data or value input, cannot hover over any object to snap to center, corner, end, etc. If you select two objects or more, gripper will not center between the two objects but stays centered on first object.
I may have a potential solution for Ventura. I'm sending some test builds for Apple notarization and will then post links in the beta forum. If you have Ventura and want to test, private message ore email me and I'll provide you access to the V14 Beta forum. Tim
I've uploaded ViaCAD, SharkCAD, and TurboCAD Mac builds 1603 into beta forum that should address Ventura. Tim
Thanks: 95 times Was thanked: 69 time(s) in 39 post(s)
Hello,
What should I do to have access to beta forum?
.. OK, have access. Thank You!
Magicart
Edited by user Sunday, October 30, 2022 3:36:53 PM(UTC)
Originally Posted by: Tim Olson I've uploaded ViaCAD, SharkCAD, and TurboCAD Mac builds 1603 into beta forum that should address Ventura. Tim
I would also like to ask for Beta access. I see the same issues under Ventura as reported in here. Thanks much Tim!
Regards,
Frank
Frank & magic art, you should have access to beta forum. I'm still finding issues with macOS Ventura and working on another build to address. Tim
2 users thanked Tim Olson for this useful post.
I've just downloaded and installed the build 1603 of Shark CAD Pro V14. On first look it looks promising. Tomorrow I will model a 3D print part to check the behaviour. Thanks for now! Any suggestion when a fix for the V12 will be available? Regards René
Hello, I cannot understand the build! I have SharkCad Pro v12 and we know it's nonfunctional on Ventura. But what is the software for the V14? Maybe, SharkCad Pro...and Punch don't want a V13 !!! What the behavior with V14 on Ventura? I need a functional application!! Tim I tried to send you a private message...and I received an Error Message!!
>> But what is the software for the V14? Download Links, videos, & feature/bug lists are in the beta forum to which you have access. Tim
V14 Build 1604 is available for testing in the beta forum. This build addresses all known issues with macOS Ventura but certainly needs more testing. Tim
Thanks: 9 times Was thanked: 16 time(s) in 13 post(s)
Can I get access to the v14 beta please? I would like to be up and running on Ventura. Thanks!
Originally Posted by: lightbulbjim Can I get access to the v14 beta please? I would like to be up and running on Ventura. Thanks!
You should now see the beta forum.
Originally Posted by: Tim Olson Originally Posted by: lightbulbjim Can I get access to the v14 beta please? I would like to be up and running on Ventura. Thanks!
Many thanks!
Thanks: 34 times Was thanked: 39 time(s) in 31 post(s)
Hi Tim Can I have access to the beta forum please, I collect my MacBook Pro today, and I’ll be moving to macOS Ventura. Really curious to see how SharkCad performs. Thanks Mike
macOS 14.3.1 (Sonoma) - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1652
Mike You should now have access to beta forum. Tim
Thanks Tim I have. 👍 I collected the Apple Silicon MacBook and upgraded to macOS Ventura. Uploaded the Beta, and uploaded Rosetta. I had Auto mode set in the Appearance setting and it was in Dark Mode, but I had to revert back to Light Mode, as I found some of the Tool icons “muddy” and harder to read especially the red dots for example in the circle type tool. Looking forward though to giving the software a workout, and it installed seamlessly. Thanks again Mike
I also have this issue and can't work at all in 3D Modeling with it. What can I do? Working with the Beta is a dangerous game. I even don't know if the Beta phase will be long enough for getting my Stuffs done until I have possible no Shark Pro licenses working on MacOS Ventura anymore. So I really need a Solution. Thanks for all and Yes: I have Beta Access. Testing was the point why I was not getting that there is a problem.... :)
Unfortunately we are still resolving issues with Ventura. I'm spending the day working out text cursor and editing issues and have some tab controls not updating correctly. Apple changed some event messaging between the OS and app that requires us to make changes.
Something I have done on my Mac is to use the "new" container partitions to install two operating systems on my Mac. I use this to keep my proven OS and check out the new OS. If you go this path, be sure to back everything up. I'm super conservative and have multiple backups because I've been "burned" too many times since my first Mac 128K.
Edited by user Tuesday, November 8, 2022 2:28:07 PM(UTC)
