ccc Curves and ccc Control Points ddd Draw Issue
Thanks: 107 times Was thanked: 112 time(s) in 74 post(s)
Hi, I actually had this problem around 2 or 3 months ago. I wish I wrote down how I previously resolved it. The problem is in a SharkCAD Pro v12 file, and even when I export to v12, even after compacting wnd resolving links beforehand, the problem travels. The problem: I invoke/call up the straight line, spline, circle, whatever, and only the helper or guidelines jitter into view. The desired geometry doesn't reveal itself until I finish or escape the operation. But, in a brand new file, in the same instance of Shark, the draw tools for lines, splines, circles, etc behaves as normal. See attached video. Steps to try to figure it out: I've gone through the menu of anything that looks like it can affect the curves being drawn. I've looked at the Gripper and Snaps, and still, I am failing. I resolved it before, so I am perplexed as to how I figured it out in minutes wheras tonight I burned over a half hour trying. Thanks for any input.
