Solid Modeling
Cannot replace parts in viewports
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
So this is one thing that is always a big trouble spot for me. I create some print out pages using the MTS, and then we need to change some of the parts. Well, I have already dimensioned these parts in the viewports. So I delete the parts I don't want anymore out of the viewport, but when I paste the new parts into the viewport, the old parts I deleted always reappear.
It ends up that I have to recreate the viewports and then re-dimension all of the new viewports affected by the changes (which is a lot).
Oftentimes, I place the dimensions in the model to avoid this, but this time, there are so many dimensions that I tried to just do it in the viewports. Sure enough, now I have to now change it.
Is there a work around, or is an update coming to fix this??
In the picture, I placed a circle around the parts that I need to change.
Sam
creativecad attached the following image(s):
(96kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
ViaCad 10 Pro ViaCad 9 Windows 10
I have figured out that I can move the problem viewport to the side. Then I create a new viewport with the new parts. I can copy the dimensions from the old viewport to the new viewport. However, I believe if I delete the old viewport it will delete the dimensions back out of the New viewport so I keep those, and print a pdf for backup. Curious if there are any other ideas.
>>So I delete the parts I don't want anymore out of the viewport Are you deleting parts in the viewport or from the parts that made the viewport? Tim
I am thinking that I have tried it both ways. It is a design change where we are removing the part(circled) and replacing it with a different part. This time though, I tried to delete the part in the viewport.
I have experimented with it on my V10 here at home, and sure enough, deleting the part in the model works like a champ. I feel a bit dumb. lol. I will try it out on the v12 at my shop tomorrow. Thank you, Tim.
1 user thanked creativecad for this useful post.
I created a layer called unused parts, and dump parts I don't want into that layer and turn it off in case I for some reason want that part later. I didn't delete the part, I just put it in my unused parts layer.
Next time, I will make a copy of it into the unused parts layer and then delete it.
Edited by user Tuesday, January 31, 2023 7:47:02 PM(UTC)
Deleting the part in the model is working every time. This makes drawing so much easier. Thanks.
Thanks: 47 times Was thanked: 341 time(s) in 226 post(s)
When you do a draw view you can make the view from layers. So if your solids are on separate layers you can select/deselect them. This had issues last time I used it and it was all reported so it may have been fixed or may not have been fixed
Solid Modeling
