MarkPen
#1 Posted : Thursday, March 9, 2023 7:28:48 AM(UTC)
MarkPen
I am new to this forum, but already using sharkcad since 2018.
There is an issue with sharkcad v14.0.0 Build(1616)
File Error
This file is damaged! Cannot read into appllication
File position: 15297895
File size: 23563049
Filename: xxx.sfx (changed because of customer name)
There are more files with these errors, what can cause this? Is there a workaround for this problem?
Regards,
Mark
Edited by user Thursday, March 9, 2023 7:32:27 AM(UTC)  | Reason: Not specified
sharkcad v14 , Macbook Pro M1, MacOS 13.0.1, Ventura
#2 Posted : Thursday, March 9, 2023 7:49:57 AM(UTC)
Mark
Can you try 1620 and let me know if the file reads in. If not, can you send me the file private.
24c
#3 Posted : Thursday, March 9, 2023 9:09:04 AM(UTC)
24c
Was thanked: 69 time(s) in 51 post(s)
Hi Tim,
I just got this on macOS too. It was caused by me forcing a shutdown of a few open applications, as I lost my mouse cursor.
I just went to open the file from the dropdown menu aka #1 and got this error, the same as the OP.
Obviously SharkCAD (1620) had unsaved changes, and I think the forced shutdown caused the problem.
Mike
Screenshot 2023-03-09 at 15.03.12.png (43kb) downloaded 0 time(s).
macOS Tahoe - v16 beta
MarkPen
#4 Posted : Friday, March 10, 2023 2:27:02 AM(UTC)
MarkPen
Mark
Hi Tim,
Thanks for your support.
Is there a download link?
When clicking on help -> version, You are running the most current build. No update is necessary
Help -> Upgrade, the complete text is not visible, but then i need to Buy a new version?
regards,
Mark
#5 Posted : Friday, March 10, 2023 3:25:10 AM(UTC)
Was thanked: 195 time(s) in 138 post(s)
No. You have already v.14. All v. 14 Updates get you for free.
Use the WIP-Builds in the Beta-Forum and not the Update-Function of the Program.
MarkPen
#6 Posted : Friday, March 10, 2023 10:40:23 AM(UTC)
MarkPen
version 1620, same problem.
Just send the files to Tim.
regards,
Mark
#7 Posted : Monday, March 13, 2023 4:25:11 AM(UTC)
Mark,
I was able correct for the larger of the two files you provided in 1621.
24c on 3/13/2023(UTC)
24c
#8 Posted : Monday, March 13, 2023 5:25:25 AM(UTC)
24c
Thanks Tim, build 1621 opened my 85Mb file successfully, that was reporting as damaged before in 1620. :)
Mike
MarkPen
#9 Posted : Monday, March 13, 2023 5:38:03 AM(UTC)
MarkPen
Mark,
Hi Tim,
Okay, i will download that version. Thanks!
And the other file? What happend there.
Regards,
Mark
