#1 Posted : Monday, May 22, 2023 2:57:00 PM(UTC)
ViaCAD, SharkCAD, TurboCAD Mac 14 Build 1632 is ready for WIP testing. You can receive links from:
http://www.masterviacad.com/beta/beta.php
Change Log 1632
—Correction converting text labels to numbers from V12 to V14
—Remove error dialog while calculation planar text polygons in repaint
—Correction for sweep profile on rails consisting of multiple paths CRASH
—Correction for sweep curves on rails consisting of multiple paths CRASH
—Correction inverting texture coordinates from read OBJ then write OBJ
Edited by user Tuesday, May 23, 2023 1:05:10 PM(UTC)  | Reason: Not specified
murrayagain
#2 Posted : Tuesday, May 23, 2023 5:45:28 AM(UTC)
murrayagain
Was thanked: 17 time(s) in 9 post(s)
Mac exclusive or Win too?
24c
#3 Posted : Tuesday, May 23, 2023 6:19:48 AM(UTC)
24c
Was thanked: 63 time(s) in 45 post(s)
@murrayagain both platforms available
Mike
GARLIC
#4 Posted : Tuesday, May 23, 2023 7:46:39 AM(UTC)
GARLIC
Was thanked: 92 time(s) in 59 post(s)
it would be quite useful to know what has been fixed / improved, any listing available ???
G.
thanks 2 users thanked GARLIC for this useful post.
damhave on 5/23/2023(UTC), TruggyDriver69 on 5/26/2023(UTC)
Jean-Francois Jacques
#5 Posted : Tuesday, May 23, 2023 8:35:42 AM(UTC)
Canada
- Perspective still not working
- Unable to link with KeyShot
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
thanks 1 user thanked Jean-Francois Jacques for this useful post.
GARLIC on 5/23/2023(UTC)
#6 Posted : Tuesday, May 23, 2023 1:05:31 PM(UTC)
>>]it would be quite useful to know what has been fixed / improved, any listing available ???
added to original post....
thanks 2 users thanked Tim Olson for this useful post.
damhave on 5/23/2023(UTC), GARLIC on 5/25/2023(UTC)
24c
#7 Posted : Tuesday, May 23, 2023 1:18:00 PM(UTC)
24c
Thanks for that @Tim
I had issues with sweeps in a model a while back, and I thought it was me. :)
Mike
#8 Posted : Tuesday, May 23, 2023 1:52:39 PM(UTC)
It was pretty messed up due to some changes in ACIS between V12 and V14.
24c on 5/23/2023(UTC), GARLIC on 5/24/2023(UTC)
relaxibus
#9 Posted : Thursday, May 25, 2023 4:06:24 AM(UTC)
relaxibus
Was thanked: 74 time(s) in 43 post(s)
is 3D PDF export now working?
24c
#10 Posted : Thursday, May 25, 2023 9:52:50 AM(UTC)
24c
@relaxibus Not for me...
I tried exporting from SharkCAD Pro and in macOS and Adobe Acrobat Reader no joy.
Another program threw up an error message, not recognising the file format "possibly 3UD"
Mike
Mark
#11 Posted : Thursday, May 25, 2023 6:12:58 PM(UTC)
Mark
“Scale values with text size” function doesn’t work properly.
- Open SharkCAD 14 v1632 and draw a line
- Dimension the line with default text size
- Now change the text size and dimension the same line again
New dimension will have different text size but all other values remain unchanged (not scaled) !!!
Edited by user Thursday, May 25, 2023 6:27:54 PM(UTC)  | Reason: Not specified
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
thanks 1 user thanked Mark for this useful post.
GARLIC on 5/26/2023(UTC)
#12 Posted : Friday, May 26, 2023 12:48:53 PM(UTC)
Yes. The correction should be available in 1633 builds.
damhave on 5/27/2023(UTC)
