Applying Shell Tool to design
Try as I may I know I'm doing something wrong. I've finally drawn the part I wanted. Now I'm needing to hollow it out, but I seem to be unable to get the shell tool to work. I think I did it wrong. I can't find a way to attach the file.
I've never used CAD before, so I'm learning as I go.
Can anyone help me?
Edited by user Wednesday, September 6, 2023 10:40:25 AM(UTC)
| Reason: Yes, I found how to attach at file.
Sleeve.0001.vc3
(12kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 34 times Was thanked: 50 time(s) in 37 post(s)
Hi James,
I'm assuming you want something like this?
Try looking at this...
http://docs.imsidesign.com/projects/ViaCAD-v14/ but essentially select the shell tool, select the surface, and it will shell normal to the workplane, you can change the thickness in the dialogue boxes too.
Mike
(126kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
macOS 14.3.1 (Sonoma) - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1652
