relaxibus
#1 Posted : Wednesday, October 4, 2023 6:57:43 AM(UTC)
relaxibus
On SharkCAD Pro v14_1641, MacOS 11.7.1
I'm trying to create a Boss feature on a curved surface in a Z-Axis. But the results shows it is centered. The Center should be at
X -150,302
Y -27,643
but the Boss center is at:
X -150,302
Y -28,187
The location of Boss center is the point placed at the coordinates above.
Same behavior occurs with holes on curved surfaces.
Edited by user Wednesday, October 4, 2023 7:00:12 AM(UTC)  | Reason: Plattform
relaxibus attached the following image(s):
thanks 1 user thanked relaxibus for this useful post.
MPSchmied on 10/10/2023(UTC)
relaxibus
#2 Posted : Monday, October 9, 2023 9:13:43 AM(UTC)
relaxibus
No replay at all?
murrayagain
#3 Posted : Monday, October 9, 2023 10:26:05 PM(UTC)
murrayagain
Was thanked: 26 time(s) in 14 post(s)
I'd create a separate cylinder or extruded circle at the coordinates and add it in if protrusion feature didn't cooperate.
relaxibus
#4 Posted : Tuesday, October 10, 2023 8:19:24 AM(UTC)
relaxibus
yeah, that's the workaround, but it didn't resolve the issue. The is a bug and have to be resolved. Same bug for holes on curved surfaces. This is annoying as it implies a lot of ore work to achieve the desired result.
thanks 3 users thanked relaxibus for this useful post.
GARLIC on 10/10/2023(UTC), MPSchmied on 10/10/2023(UTC), damhave on 10/10/2023(UTC)
relaxibus
#5 Posted : Monday, December 4, 2023 2:57:19 AM(UTC)
relaxibus
Now 2 months have past, I would like to remind this bug as I get steps into this again and again.
PunchCAD Support: What is your action on this?
thanks 2 users thanked relaxibus for this useful post.
GARLIC on 12/4/2023(UTC), damhave on 12/4/2023(UTC)
#6 Posted : Monday, December 4, 2023 4:39:48 PM(UTC)
Unfortunately I cannot repeat, likely my steps are not the same.
Do you have a simple file with steps to repeat?
rockyroad_us
#7 Posted : Tuesday, December 5, 2023 10:39:15 AM(UTC)
rockyroad_us
Yeah, I cannot repeat either. Looks like the boss Normal was chosen instead. That's the only case were the center of the top will not be centered to say a point on the surface or a circle in the x-y plane at that surface location.
relaxibus
#8 Posted : Friday, December 8, 2023 11:16:31 AM(UTC)
relaxibus
will check again and let you know.
