Solid Modeling
BUG: Boss doesn't work properly on curved surfaces
Thanks: 7 times Was thanked: 79 time(s) in 45 post(s)
On SharkCAD Pro v14_1641, MacOS 11.7.1
I'm trying to create a Boss feature on a curved surface in a Z-Axis. But the results shows it is centered. The Center should be at
X -150,302
Y -27,643
but the Boss center is at:
X -150,302
Y -28,187
The location of Boss center is the point placed at the coordinates above.
Same behavior occurs with holes on curved surfaces.
Edited by user Wednesday, October 4, 2023 7:00:12 AM(UTC)
| Reason: Plattform
relaxibus attached the following image(s):
(83kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked relaxibus for this useful post.
Was thanked: 26 time(s) in 14 post(s)
I'd create a separate cylinder or extruded circle at the coordinates and add it in if protrusion feature didn't cooperate.
yeah, that's the workaround, but it didn't resolve the issue. The is a bug and have to be resolved. Same bug for holes on curved surfaces. This is annoying as it implies a lot of ore work to achieve the desired result.
3 users thanked relaxibus for this useful post.
Now 2 months have past, I would like to remind this bug as I get steps into this again and again. PunchCAD Support: What is your action on this?
2 users thanked relaxibus for this useful post.
Unfortunately I cannot repeat, likely my steps are not the same. Do you have a simple file with steps to repeat? Tim
Yeah, I cannot repeat either. Looks like the boss Normal was chosen instead. That's the only case were the center of the top will not be centered to say a point on the surface or a circle in the x-y plane at that surface location.
will check again and let you know.
Solid Modeling
