TruggyDriver69
#1 Posted : Tuesday, January 9, 2024 11:00:24 AM(UTC)
TruggyDriver69
As mentioned in the description. I make a circle and go to push the circle using the push pull tool but it only extrudes and doesn't make a hole. Never had this problem before, so now I'm stuck at this point because I can no longer make holes other than from a circle in the 2d drawing. At this point the software is completely useless if I can't make holes where needed. Mac OS Sonoma 14.2.1 Viacad 14.1 build 1641.
MaiFy
#2 Posted : Tuesday, January 9, 2024 8:38:36 PM(UTC)
MaiFy
Hi Truggy
I'm a windows user so cant help you there.
Not sure if this helps. As a workaround until it gets sorted.
Perhaps extrude a cylinder.
Align it with the circle on the solid and use the subtract tool to create the hole you want.
Not ideal but keeps you moving.
24c
#3 Posted : Wednesday, January 10, 2024 1:21:01 AM(UTC)
24c
Was thanked: 64 time(s) in 46 post(s)
Hi Truggy,
I'm using the same OS, but I never use the Push Pull tool to make holes, just this one "CutOut Solid", which takes any closed planar group and makes a hole through a solid for a given direction ("z" in my case).
Mike
Edited by user Wednesday, January 10, 2024 1:26:16 AM(UTC)  | Reason: Clarity
macOS Tahoe - v16 beta
Theo5715
#4 Posted : Thursday, January 11, 2024 10:50:36 AM(UTC)
Theo5715
Netherlands
Was thanked: 24 time(s) in 15 post(s)
Hi Truggy,
I'm using Sharkcad v14.0 build (1625)
PowerPacked
Windows
Sometimes I had the same problem
After using: Tools-Snap-Face on to draw the circle to push-pull it works great for me.
But the answer from 24c also does the job...
Good luck, Theo
Edited by user Thursday, January 11, 2024 10:54:14 AM(UTC)  | Reason: Not specified
If things don't go the way you would find a way it could.
rockyroad_us
#5 Posted : Friday, January 12, 2024 10:45:06 AM(UTC)
rockyroad_us
You will have to draw the circle on the surface, dead on. After, you select the circle and then use the push-pull and it should do the negative instead of extruding. That's how I know it.
damhave
#6 Posted : Friday, January 12, 2024 1:45:10 PM(UTC)
damhave
Denmark
Was thanked: 77 time(s) in 45 post(s)
It seems to work for me (tested on Mac OS Sonoma 14.2.1 SharkCad 14.1. OBS with buiild 1645. But sometimes I have to select both the face and the circle with the select tool before it will extrude. Extrude works in both directions - no problem with holes.
kind regards
Danny
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
TruggyDriver69
#7 Posted : Sunday, January 14, 2024 6:43:33 AM(UTC)
TruggyDriver69
I ended up closing the program and reopening it and it works now, but unfortunately I'm having a more severe problem now w/ my models will just disappear without a trace when zooming out. I'm not zooming out so far that I can't see the model but the second I start to zoom out the model just dissapears. This has happened twice now.
Guest (5)
