strangebru
#1 Posted : Friday, January 5, 2024 11:29:47 AM(UTC)
strangebru
I like to use the Deep Select tool to select and change the color of certain surfaces on solids.
When I first upgraded to SharkCAD Pro v14 any models that I had done that too lost the alternate color. I raised that issue and Build 1621 fixed the problem. I just updated to Build 1645 and it's back to where it started. I can use the Deep Select tool to select one of the surfaces that I had changed color and the object pen palette shows the color that is should be, but it doesn't display that way on the screen. I have also found that if you render the image that the color shows up like it should.
Somebody found and fixed the issue once but it apparently got lost.
Is there a way that I can go back to Build 1621?
strangebru
#2 Posted : Thursday, January 11, 2024 8:28:34 AM(UTC)
strangebru
Is anyone able to change surface colors on a solid using the deep select tool with Build 1645?
damhave
#3 Posted : Thursday, January 11, 2024 11:27:38 AM(UTC)
damhave
Denmark
Was thanked: 80 time(s) in 47 post(s)
It does not work for me either (tested on MacOS Sonoma 14.2.1). Only with the PBR rendering
kind regards
Danny
Edited by user Thursday, January 11, 2024 3:14:22 PM(UTC)  | Reason: os specified
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
SharkCAD v14 Pro(1653),
MacBook Pro 14 2023,M3
strangebru
#4 Posted : Wednesday, January 17, 2024 3:15:13 PM(UTC)
strangebru
It's a little frustrating as I raised this issue before and it got fixed in build 1621 but now it's broken again. I use that function often.
thanks 1 user thanked strangebru for this useful post.
damhave on 1/17/2024(UTC)
damhave
#5 Posted : Wednesday, January 17, 2024 11:46:14 PM(UTC)
damhave
Denmark
Hi Strangebru, I also reported the issue in the previous version...
kind regards
Danny
Edited by user Thursday, January 18, 2024 10:43:09 AM(UTC)  | Reason: changes to clarify meaning
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
#6 Posted : Wednesday, January 24, 2024 5:32:59 PM(UTC)
>>I just updated to Build 1645 and it's back to where it started. I can use the Deep Select tool to select one of the surfaces that I had changed color and the object pen >>palette shows the color that is should be, but it doesn't display that way on the screen.
Confirmed bug, looking into a fix for the the next patch. Thank for the heads up.
damhave on 1/26/2024(UTC)
#7 Posted : Sunday, January 28, 2024 5:26:57 PM(UTC)
Thanks again for the heads up, this is now fixed in the 1647 builds. I should have a WIP ready for interested parties shortly.
strangebru
#8 Posted : Wednesday, January 31, 2024 7:53:09 AM(UTC)
strangebru
As an interested party, how will I know when a build 1647 is ready and how to get it?
damhave
#9 Posted : Wednesday, January 31, 2024 8:19:41 AM(UTC)
damhave
Denmark
New WIP build downloads will usually be released for download here:
https://masterviacad.com/beta/beta.php
I just checked and it is still not available. My best guess is that Tim will post in this thread when it is available
@Tim please add release notes to help us reporting bugs...
kind regards
Danny
Edited by user Wednesday, January 31, 2024 9:13:18 AM(UTC)  | Reason: Not specified
BR
Danny
Win10 Pro,
Dell XPS 15
Sonoma 14.7.1
#10 Posted : Wednesday, January 31, 2024 8:31:50 AM(UTC)
I will be sure to note in the forum when it is ready.
I'm sending a 1647 build to one user today to check some things and then will expand.
thanks 4 users thanked Tim Olson for this useful post.
GARLIC on 1/31/2024(UTC), damhave on 1/31/2024(UTC), strangebru on 2/1/2024(UTC), jlm on 2/3/2024(UTC)
#11 Posted : Friday, February 2, 2024 11:18:56 PM(UTC)
Update:
We have made a couple of passes and now on 1649.
In addition to progress related to Deep Select, fixing other issues users reported to customer support.
Getting closer but need the weekend to fix and confirm addition items are fixed and ready for a WIP.
thanks 5 users thanked Tim Olson for this useful post.
GARLIC on 2/3/2024(UTC), damhave on 2/3/2024(UTC), jlm on 2/3/2024(UTC), 24c on 2/4/2024(UTC), mitchb on 2/4/2024(UTC)
#12 Posted : Monday, February 5, 2024 8:59:47 AM(UTC)
Still fixing some priority items...getting closer....
thanks 3 users thanked Tim Olson for this useful post.
damhave on 2/5/2024(UTC), GARLIC on 2/5/2024(UTC), creativecad on 2/5/2024(UTC)
Jean-Francois Jacques
#13 Posted : Monday, February 5, 2024 10:46:52 AM(UTC)
Canada
Nice to know Tim, do you have schedule for the Perspective View ??
Tim thanks again for your excellent work !
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
Guest (11)
