relaxibus
#1 Posted : Monday, July 1, 2024 6:38:55 AM(UTC)
relaxibus
I did a Explode Curve on a solid and the line weight shows a different style now. After this, any Shark v14 version I have shows the same behavior. On the attached picture you see the original line weight (thin) of 1 pixel and the Explode Curve line weight (fat) of 1 pixel. Only if I select a different weight of 0.5 pixel, the it shows same as the original 1 pixel lines.
Need to get this resolved soon!
MacOS 12 on M1
Edited by user Monday, July 1, 2024 6:39:44 AM(UTC)  | Reason: Not specified
relaxibus attached the following image(s):
Line Weight_missmatch.jpg (144kb) downloaded 4 time(s).
thanks 1 user thanked relaxibus for this useful post.
damhave on 7/1/2024(UTC)
relaxibus
#2 Posted : Friday, July 5, 2024 1:45:17 AM(UTC)
relaxibus
This is what I do mean with "Support". after 4 days NO answer from Punch!
damhave on 7/5/2024(UTC)
