Suggestions
Illustrator Export - Line Weight (#943)
It would be nice if when you exported as an Adobe Illustrator file that the line weight and pattern exported, too.
Agreed, looks like it might be a scaling or unit issue. Line weights defined in mm as 1mm, 0.5mm and 2mm in Shark FX open in Illustrator as 0.5mm, 0.25mm and 1mm. All the best Nick
dexter wrote: It would be nice if when you exported as an Adobe Illustrator file that the line weight and pattern exported, too.
I think that the AI export needs a through re-think. At the moment it exports everything as lines, it would be a lot more useful if each face was exported as a closed polygon.
Suggestions
