martinwh99
#1 Posted : Sunday, March 16, 2025 12:30:11 AM(UTC)
martinwh99
Switzerland
Hello
Im using Viacad 12 with WIN 11.
I have a problem to substract solids. I allways get the following ACSI Error:
system inconsistency processing surface tangancy
Can someone please help me. Thanks.
kind regards
Martin
Substract Solid.vcp (1,981kb) downloaded 14 time(s).
Martin Krueger
ViaCAD Pro V12 PowerPacked, Cut2D, Cut3D
#2 Posted : Sunday, March 16, 2025 6:58:40 AM(UTC)
Did you create this wing with ViaCAD? This solid may have too many overlaps.
Clipboard 1.png (577kb) downloaded 15 time(s).
martinwh99 on 3/16/2025(UTC)
martinwh99
#3 Posted : Sunday, March 16, 2025 8:19:23 AM(UTC)
martinwh99
Switzerland
Yes, I created it with ViaCAD. Now I recreated it and it worked, thanks. The question that remains is - why did function Add Solid leave the overlap?
kind regards
Martin
Martin Krueger
thanks 1 user thanked martinwh99 for this useful post.
MPSchmied on 3/16/2025(UTC)
Theo5715
#4 Posted : Wednesday, April 2, 2025 9:14:56 AM(UTC)
Theo5715
Netherlands
Was thanked: 34 time(s) in 21 post(s)
Hi Martin,
It looks like your second part is not a proper solid
Theo5715 attached the following image(s):
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
