Mark
#1 Posted : Tuesday, July 22, 2025 4:04:02 PM(UTC)
Mark
It looks like My Shark 15 on MacOS 13.7.6 got corrupted.
My horizontal dimension now works as vertical and vertical works as horizontal.
“Collapse to top” setting does not show up in “Inspector” when you right click on it.
There are other problems as well.
So far I have tried to set SharkCAD settings to “Factory All” and deleted/reinstalled the program but nothing works.
Does anyone have any suggestions?
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
#2 Posted : Thursday, July 24, 2025 6:46:54 AM(UTC)
Was thanked: 202 time(s) in 140 post(s)
Download SharkCAD15 Build 1736.
If this does not help, please delete all config files after removing the application, and then reinstall it.
If this still does not help, update your Mac to version 15.
Edited by user Thursday, July 24, 2025 6:47:31 AM(UTC)  | Reason: Not specified
Mark
#3 Posted : Thursday, July 24, 2025 9:50:44 AM(UTC)
Mark
Thank you MPSchmied.
Where can I find "config" files that you mention?
#4 Posted : Saturday, July 26, 2025 2:45:56 PM(UTC)
I don't have a Mac, but according to AI research, the path should be
Code:
~/Library/Application Support/Punch!/
mitchb
#5 Posted : Saturday, July 26, 2025 8:37:05 PM(UTC)
mitchb
Was thanked: 76 time(s) in 38 post(s)
From the "GO" menu, click on "Home" -> "Library" -> "Application Support". Look for "com.encore.shark15esd". Delete this file.
thanks 3 users thanked mitchb for this useful post.
GARLIC on 7/27/2025(UTC), MPSchmied on 7/27/2025(UTC), Mark on 7/27/2025(UTC)
Mark
#6 Posted : Sunday, July 27, 2025 3:00:18 PM(UTC)
Mark
It worked!
Thank you mitchb
