How to reset corrupted SharkCAD 15 app on Mac?
Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
It looks like My Shark 15 on MacOS 13.7.6 got corrupted. My horizontal dimension now works as vertical and vertical works as horizontal. “Collapse to top” setting does not show up in “Inspector” when you right click on it. There are other problems as well. So far I have tried to set SharkCAD settings to “Factory All” and deleted/reinstalled the program but nothing works. Does anyone have any suggestions?
Intel iMac-20,2 | macOS Ventura 13.3.1 | SharkCAD 14 |
Thanks: 320 times Was thanked: 193 time(s) in 137 post(s)
Download SharkCAD15 Build 1736 .
If this
does not help , please delete all
config files after removing the application, and then reinstall it.
If this still
does not help , update your Mac to version
15 .
Edited by user Thursday, July 24, 2025 6:47:31 AM(UTC)
Originally Posted by: MPSchmied Download SharkCAD15 Build 1736 .
If this
If this still
15 .
Thank you MPSchmied.
Where can I find "config" files that you mention?
I don't have a Mac, but according to AI research, the path should be
Code: ~/Library/Application Support/Punch!/
Thanks: 8 times Was thanked: 76 time(s) in 38 post(s)
From the "GO" menu, click on "Home" -> "Library" -> "Application Support". Look for "com.encore.shark15esd". Delete this file.
3 users thanked mitchb for this useful post.
Originally Posted by: mitchb From the "GO" menu, click on "Home" -> "Library" -> "Application Support". Look for "com.encore.shark15esd". Delete this file.
It worked!
Thank you mitchb
