24c
#1 Posted : Tuesday, September 16, 2025 6:51:55 AM(UTC)
24c
Was thanked: 67 time(s) in 49 post(s)
Hi
Anyone having issues with macOS Tahoe and Shark CAD Pro.
It's leaving drop down menu items on the desktop, needs a Quit to resolve
Force Quit doesn't show it "Not responding" though
My beta for v16 has expired, so can't test that.
Cheers
Mike
PS I'm trying to open Recent Items in the drop down, so maybe the file structurer has changed, as it crashes and quits trying to open some of these files.
Edited by user Tuesday, September 16, 2025 6:52:37 AM(UTC)  | Reason: typo
Screenshot 2025-09-16 at 13.47.59.png (867kb) downloaded 12 time(s).
macOS Tahoe - v16 beta
robbeh
#2 Posted : Thursday, September 18, 2025 2:14:38 AM(UTC)
robbeh
since switching to Tahoe, I get serious trouble working with Shark pro 14.1.0 (Build 1654). Drop down menus stoped working, also tools like extrude stopped working, since no object can be selected. Will this be fixed?
Thanks, Robert
24c
#3 Posted : Thursday, September 18, 2025 7:39:03 AM(UTC)
24c
Hi Robert,
I'm on the same build, and I'm getting more issues, sometimes the Entity what show the ops, and I can't expand in Concept Explorer to alter chamfers etc
Tried quitting and re-booting, but no joy.
Definitely an issue with screen redraw and updating, as highlighting a part doesn't update the open window in concept explorer
Very frustrating, but I'd be interested if anyone is OK using a 16 Beta or a later build of 15.
I see the forum has been pretty quiet, not sure if it's monitored by support.
Mike
24c
#4 Posted : Thursday, September 18, 2025 7:51:11 AM(UTC)
24c
Hi again
Just an update in Concept Explorer, if I click on a part in the drawing, it is not identified in Concept Explorer's Entities tab, but if I click on Layers or Symbols, when I go back to Entities I can se the History Tree, so evrytime it locks out, and becomes unresponsive, I just switch into another tab, and then back to the original tab.... something simple, that's changed in the macOS side, that's not playing nice. :)
Mike
#5 Posted : Thursday, September 18, 2025 9:02:11 AM(UTC)
Was thanked: 173 time(s) in 105 post(s)
Hello,
With SCP V16 b1732 :
I can confirm many interface issue as mentioned before for V15 :
Menus defect, tools changing icons, Explorer loosing control....
But let's see a positive point : there is far less crashes and hangs than before upgrading to Tahoe.
Hatching complex sections copy and paste or export heavy solids are working better than ever.
---> May be a Rosetta finally learned Shark's language ???
Edited by user Thursday, September 18, 2025 9:04:07 AM(UTC)  | Reason: Not specified
24c
#6 Posted : Thursday, September 18, 2025 11:18:46 AM(UTC)
24c
Thanks for that, I'm hoping the software team are on the case, not being negative just surprised, and BTW for me, the V16 Beta was a big improvement in a few areas vs previous beta tests. Maybe I shouldn't have "upgraded" to macOS Tahoe. :)
Mike
PS I suspect it's more to do with graphics engine changes, or newer guidelines not yet adopted.
Claus3
#7 Posted : Friday, September 19, 2025 2:08:23 AM(UTC)
Claus3
I cant create or delete layers in the layers palette...
Claus
OK, this seems to be related to using external monitor in my case. If I open my macbook both displays will update. So clicking to create a new layer actually creates the layer but it will not show until a screen update is invoked. As a workaround I have my laptop close to my left hand and lift the lid to refresh. Hopefully not for long.
Edited by user Friday, September 19, 2025 2:36:34 AM(UTC)  | Reason: Not specified
24c
#8 Posted : Friday, September 19, 2025 3:56:12 AM(UTC)
24c
Hi Claus,
I'm using an external monitor with my MacBook open, but useful to know.
I'm not sure how long before there is a fix for v14, as I suspect it'll roll into a v16 upgrade. My understanding sometime ago was the software team don't have access to an Apple Silicon Mac or use an external monitor, but I'm not sure how many macOS users there are using their software vs Windows OSes
Mike
#9 Posted : Friday, September 19, 2025 4:45:41 AM(UTC)
Clever Workaround Claus !
On my side, I have set collapsible layer palette.
Collapsing and expending the palette does the same refresh...
Too bad it doesn't solve the entity tree...
JL
#10 Posted : Friday, September 19, 2025 6:03:58 AM(UTC)
Was thanked: 190 time(s) in 135 post(s)
collapsible layer paletteL
Do you mean the Concept Explorer or a "collapsible layer palette"?
Claus3
#11 Posted : Friday, September 19, 2025 9:17:14 AM(UTC)
Claus3
I emailed Tim Olson and he is working on it...
thanks 1 user thanked Claus3 for this useful post.
jlm on 9/19/2025(UTC)
Claus3
#12 Posted : Friday, September 19, 2025 9:19:00 AM(UTC)
Claus3
Great tip, much easier. Thanks!!
JL
24c
#13 Posted : Friday, September 19, 2025 11:14:35 AM(UTC)
24c
I find if I switch back and firth in Concept Explorer when looking at the Entities that don't show anything, that switching to Layers and switching back is enough to force a refresh and see the history... then you can go into this, but anytime it locks out or doesn't update say when Remove Feature etc, I just switch somewhere and switch back.
Works for me, just doing frequent saves too. :)
Mike
neotericsimian
#14 Posted : Thursday, October 16, 2025 3:47:45 AM(UTC)
neotericsimian
Was thanked: 3 time(s) in 1 post(s)
Giving this a bump. Has anything been done? I have VC Pro 15 and it is useless with Tahoe - the program hangs constantly (my only option is a force quit), Concept Explorer doesn't work: can't hide layers, can't switch focus, can't create new layers (truth to tell it does create the layer but doesn't show it in the CE so I can't use it).
I don't know if there are other errors because the program hangs within minutes. It is NOT usable.
Oscar
thanks 3 users thanked neotericsimian for this useful post.
Ovocom on 10/16/2025(UTC), MPSchmied on 10/16/2025(UTC), damhave on 10/16/2025(UTC)
Ovocom
#15 Posted : Friday, October 17, 2025 1:21:23 AM(UTC)
Ovocom
France, Metropolitan
Was thanked: 7 time(s) in 4 post(s)
Hi.
The question is: When V16 will be out as it seems the only one that work with Mac OS 26?
Turbocad Mac 16 is already available, so why Sharkcad / Viacad still waiting?
nelsonex
#16 Posted : Sunday, October 19, 2025 3:08:05 PM(UTC)
nelsonex
I am new to viaCAD 15 for the Mac and have experienced the same refresh problem with Concept Explorer. I accidentally stumbled on the workaround already mentioned of switching from the Layers tab to any other tab (Entities, Symbols, Co-pilot)then switching back to the Layers tab.
I am running viaCAD 15 v15.0.15 Build(1722) / Tahoe (macOs 26.0.1) / Mac mini M4, 24GB Ram, booting from an external 2TB M2 SSD. I've had a few crashes and freezes but haven't lost anything important yet.
I am switching to CAD software that will run natively on the Mac. I have been running TurboCAD for Window on virtual machines for at least 25 years. I tried for days to get TurboCAD running but couldn't. Here's what did not work for me: TurboCAD/Windows11/VMware Fusion 13/Tahoe/Mac mini M4. -Nelson
Ovocom
#17 Posted : Wednesday, October 22, 2025 8:10:19 AM(UTC)
Ovocom
V.16 is finally out today: https://www.punchcad.com
It's Mac OS Tahoe compatible.
thanks 1 user thanked Ovocom for this useful post.
MPSchmied on 10/22/2025(UTC)
#18 Posted : Wednesday, October 22, 2025 12:46:48 PM(UTC)
Here is the link to the description: https://www.punchcad.com...dtm-sharkcadr-viacadr-16
I think I need to buy this upgrade because what I really need is faster redraw and loading.
Edited by user Wednesday, October 22, 2025 12:49:00 PM(UTC)  | Reason: Not specified
andreaswieneke
#19 Posted : Saturday, October 25, 2025 8:15:56 AM(UTC)
andreaswieneke
Originally Posted by: 24c Go to Quoted Post
Hi again
Mike
I'm with you.
I'm waiting for
a accommodating agreement
for all of us. who do not need the upgrade, but have to do it
best wishes
Andreas
since ViaCad 5 with punch, now > SharkCad 15 , Mac
andreaswieneke
#20 Posted : Saturday, October 25, 2025 8:42:40 AM(UTC)
andreaswieneke
any answer ?
Tim is the soul of punchCad . Hope she rest will understand
best wishes
Andreas
thanks 1 user thanked andreaswieneke for this useful post.
damhave on 10/27/2025(UTC)
Guest (13)
