24c
#1 Posted : Tuesday, September 16, 2025 6:51:55 AM(UTC)
24c
Was thanked: 64 time(s) in 46 post(s)
Hi
Anyone having issues with macOS Tahoe and Shark CAD Pro.
It's leaving drop down menu items on the desktop, needs a Quit to resolve
Force Quit doesn't show it "Not responding" though
My beta for v16 has expired, so can't test that.
Cheers
Mike
PS I'm trying to open Recent Items in the drop down, so maybe the file structurer has changed, as it crashes and quits trying to open some of these files.
Edited by user Tuesday, September 16, 2025 6:52:37 AM(UTC)  | Reason: typo
Screenshot 2025-09-16 at 13.47.59.png (867kb) downloaded 10 time(s).
macOS Tahoe - v16 beta
robbeh
#2 Posted : Thursday, September 18, 2025 2:14:38 AM(UTC)
robbeh
since switching to Tahoe, I get serious trouble working with Shark pro 14.1.0 (Build 1654). Drop down menus stoped working, also tools like extrude stopped working, since no object can be selected. Will this be fixed?
Thanks, Robert
24c
#3 Posted : Thursday, September 18, 2025 7:39:03 AM(UTC)
24c
Hi Robert,
I'm on the same build, and I'm getting more issues, sometimes the Entity what show the ops, and I can't expand in Concept Explorer to alter chamfers etc
Tried quitting and re-booting, but no joy.
Definitely an issue with screen redraw and updating, as highlighting a part doesn't update the open window in concept explorer
Very frustrating, but I'd be interested if anyone is OK using a 16 Beta or a later build of 15.
I see the forum has been pretty quiet, not sure if it's monitored by support.
Mike
24c
#4 Posted : Thursday, September 18, 2025 7:51:11 AM(UTC)
24c
Hi again
Just an update in Concept Explorer, if I click on a part in the drawing, it is not identified in Concept Explorer's Entities tab, but if I click on Layers or Symbols, when I go back to Entities I can se the History Tree, so evrytime it locks out, and becomes unresponsive, I just switch into another tab, and then back to the original tab.... something simple, that's changed in the macOS side, that's not playing nice. :)
Mike
#5 Posted : Thursday, September 18, 2025 9:02:11 AM(UTC)
Was thanked: 171 time(s) in 103 post(s)
Hello,
With SCP V16 b1732 :
I can confirm many interface issue as mentioned before for V15 :
Menus defect, tools changing icons, Explorer loosing control....
But let's see a positive point : there is far less crashes and hangs than before upgrading to Tahoe.
Hatching complex sections copy and paste or export heavy solids are working better than ever.
---> May be a Rosetta finally learned Shark's language ???
Edited by user Thursday, September 18, 2025 9:04:07 AM(UTC)  | Reason: Not specified
24c
#6 Posted : Thursday, September 18, 2025 11:18:46 AM(UTC)
24c
Thanks for that, I'm hoping the software team are on the case, not being negative just surprised, and BTW for me, the V16 Beta was a big improvement in a few areas vs previous beta tests. Maybe I shouldn't have "upgraded" to macOS Tahoe. :)
Mike
PS I suspect it's more to do with graphics engine changes, or newer guidelines not yet adopted.
Claus3
#7 Posted : Friday, September 19, 2025 2:08:23 AM(UTC)
Claus3
I cant create or delete layers in the layers palette...
Claus
OK, this seems to be related to using external monitor in my case. If I open my macbook both displays will update. So clicking to create a new layer actually creates the layer but it will not show until a screen update is invoked. As a workaround I have my laptop close to my left hand and lift the lid to refresh. Hopefully not for long.
Edited by user Friday, September 19, 2025 2:36:34 AM(UTC)  | Reason: Not specified
24c
#8 Posted : Friday, September 19, 2025 3:56:12 AM(UTC)
24c
Hi Claus,
I'm using an external monitor with my MacBook open, but useful to know.
I'm not sure how long before there is a fix for v14, as I suspect it'll roll into a v16 upgrade. My understanding sometime ago was the software team don't have access to an Apple Silicon Mac or use an external monitor, but I'm not sure how many macOS users there are using their software vs Windows OSes
Mike
#9 Posted : Friday, September 19, 2025 4:45:41 AM(UTC)
Clever Workaround Claus !
On my side, I have set collapsible layer palette.
Collapsing and expending the palette does the same refresh...
Too bad it doesn't solve the entity tree...
JL
#10 Posted : Friday, September 19, 2025 6:03:58 AM(UTC)
Was thanked: 187 time(s) in 133 post(s)
collapsible layer paletteL
Do you mean the Concept Explorer or a "collapsible layer palette"?
Claus3
#11 Posted : Friday, September 19, 2025 9:17:14 AM(UTC)
Claus3
I emailed Tim Olson and he is working on it...
thanks 1 user thanked Claus3 for this useful post.
jlm on 9/19/2025(UTC)
Claus3
#12 Posted : Friday, September 19, 2025 9:19:00 AM(UTC)
Claus3
Great tip, much easier. Thanks!!
JL
24c
#13 Posted : Friday, September 19, 2025 11:14:35 AM(UTC)
24c
I find if I switch back and firth in Concept Explorer when looking at the Entities that don't show anything, that switching to Layers and switching back is enough to force a refresh and see the history... then you can go into this, but anytime it locks out or doesn't update say when Remove Feature etc, I just switch somewhere and switch back.
Works for me, just doing frequent saves too. :)
Mike
