Rendering & Display
Dynamic Rotate & Dinamic View, unusable refresh rate crawls. Shark Pro V16
Thanks: 23 times Was thanked: 8 time(s) in 6 post(s)
Shark Pro V16.0.41, Build 1841 macOS Tahoe 26.3.1 Macbook M3 Pro 1. Dynamic Rotate is unusable the refresh rate drops to about 1 frame (I'm not exaggerating) regardless of the amount of movement. 2. On the external monitor (main monitor) is completely unresponsive. On macbook's monitor it lags a littler less. 3. PS: The program windows become unusable if app is moved between desktops. No way to re arrange them.
Lowering the components resolution to medium made it fairly usable
Edited by user Sunday, March 22, 2026 7:36:17 PM(UTC)
Thanks: 9 times Was thanked: 33 time(s) in 20 post(s)
Hi, Your problem: Dynamic Rotate is unusable the refresh rate drops to about 1 frame (I'm not exaggerating) regardless of the amount of movement If you like to rotate it's better to turn off the construction line (normally in construction layer), these lines are extreme long and ruins the dynamic rotation. Good luck & regard, Theo
If things don't go the way you would find a way it could. Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
Rendering & Display
