V. 16 Snap points do not work correctly
Thanks: 351 times Was thanked: 255 time(s) in 168 post(s)
When drawing a line that runs close to the x- or y-axis, the snap point is not used; instead, the line is drawn parallel to the x- or y-axis. I cannot work this way.I am going back to V 9.
Edited by user Tuesday, April 14, 2026 6:23:43 AM(UTC)
6 users thanked MPSchmied for this useful post.
Originally Posted by: MPSchmied When drawing a line that runs close to the x- or y-axis, the snap point is not used; instead, the line is drawn parallel to the x- or y-axis. I cannot work this way.I am going back to V 9.
Yes, it is an issue.
It can generate mistakes.
In some cases we can solve it by zooming.
See video attached
Enregistrement de l’écran 2026-04-22 à 13.51.50-480.mov
(2,656kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
3 users thanked jlm for this useful post.
Thanks: 37 times Was thanked: 16 time(s) in 14 post(s)
on Mac v16 the little snap to hoover doesn't work, and when it does the verbiage is ignored. like if you are pulling a line perpendicular to a curve the line will say perpendicular in the snap hoover then when mouse released the line is snapped to xy. frustrating.
1 user thanked memphisjed for this useful post.
There is a solution for the problem. Write an email to support<at>punchsoftware.com, and Todd will send you Build 1841. This build is not available at http://www.masterviacad.com/beta/beta.php no also build 1841 works not properly, same problem.....
Edited by user Monday, April 27, 2026 9:55:54 AM(UTC)
Tim Olsen said via email that he fixed this problem in V17 builds,
but he did not tell me where I can get V17. Edited by user Tuesday, April 28, 2026 12:23:59 PM(UTC)
Originally Posted by: MPSchmied Tim Olsen said via email that he fixed this problem in V17 builds, but he did not tell me where I can get V17.
Yes, it seams to be OK now on V17 beta...
1 user thanked jlm for this useful post.
