Theo5715
#1 Posted : Wednesday, June 3, 2026 7:05:42 AM(UTC)
Theo5715
Netherlands
Was thanked: 49 time(s) in 29 post(s)
From Theo
How to draw a bracelet :-)
https://youtu.be/O7_UKgMNbng
Kind regards, Theo
Theo5715 attached the following image(s):
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
thanks 3 users thanked Theo5715 for this useful post.
ZeroLengthCurve on 6/3/2026(UTC), MPSchmied on 6/3/2026(UTC), scruff007 on 6/26/2026(UTC)
#2 Posted : Wednesday, June 3, 2026 12:20:09 PM(UTC)
You know that you always get the Dynamic Rotate tool in Stream when you press Alt and the right mouse button or the middle mouse button? You can also change the Dynamic Rotate midpoint in Stream while using another tool with Alt + right mouse button and Ctrl + click at the new midpoint. For snaps enabled, use the Measure tool or select the item before changing the midpoint. Sometimes, to fully exit the in-Stream Dynamic Rotate after changing the midpoint, you need to press Ctrl again to exit and enable changing the view with customized buttons again.
Edited by user Wednesday, June 3, 2026 12:32:07 PM(UTC)  | Reason: Not specified
Theo5715 on 6/3/2026(UTC)
Theo5715
#3 Posted : Wednesday, June 3, 2026 1:19:21 PM(UTC)
Theo5715
Netherlands
Hi MP,
Dynamic rotation with the Alt key and right mouse button I know.
I use it a lot to blend edges for example but in this case I didn't had to use another tool while I was rotating.
Also with the microphone and recording on distracts me from some logical handlings....
However a good remark yours for everyone.
The rest I didn't know, I will test your comment, thanks a lot!
MFG, Kind regards, Theo
Edited by user Wednesday, June 3, 2026 1:25:19 PM(UTC)  | Reason: Not specified
