Suggestions
Fix the old Bug Skewed "Bounding Box"
Thanks: 351 times Was thanked: 255 time(s) in 168 post(s)
If an object does run parallel to the base surface but not quite to the y-axis, and you therefore create a work plane perpendicular to the centerline and then create a bounding box, then the bounding box becomes skewed. I noticed that when I wanted to trim something with a makeshift template and it failed with this pipe.
(138kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 11 times Was thanked: 49 time(s) in 29 post(s)
Hi MP,
It looks like you did a cutout of the pipe and the cutout was not perpendicular to the pipe.
Look at the 2 red stripes in my image.
If I draw a construction line below it is parallel with the line above so it looks like that the cutout was not perpendicular with the pipe..?
And when did you draw the bounding box, before or after you created the work plane?
Edited by user Monday, June 8, 2026 10:01:24 AM(UTC)
Theo5715 attached the following image(s):
(14kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
If things don't go the way you would find a way it could. Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
Originally Posted by: Theo5715 It looks like you did a cutout of the pipe and the cutout was not perpendicular to the pipe.
No. Here is the file. I exported it to version 9 so that you can open it with older versions.
Edited by user Tuesday, June 9, 2026 2:13:23 AM(UTC)
AD00609a.sfx
(32kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Hi MP,
Got your point.
I did draw your pipe (o.5 degree out of Y axis) with box without this problem.
I think I know what is the problem:
At the moment you like to draw a box perpendicular to the pipe use the workplane as you did.
Than select the menu View - View The Plane and then draw the box. No problem in my case.
Regard, Theo
Edited by user Tuesday, June 9, 2026 4:55:03 AM(UTC)
MP2.sfx
(19kb) downloaded 2 time(s). Theo5715 attached the following image(s):
(29kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked Theo5715 for this useful post.
By the way, how about an intelligent bounding box that is automatically perpendicular to the pipe? Setting the workplane is too much work, and changing the view—I have bound a button for this.
Thanks: 633 times Was thanked: 103 time(s) in 65 post(s)
??? wow..: how did you do it?, sounds very interesting and useful !
Suggestions
