I had it running on MacOS 26 and in my simple use I have had no problems.
It did crash on closing, disappointing, but, not fatal. Did not crash while using it.
I have been doing 2/3D drawings, not, solids etc.
Just attempted to run on MacOs 27 and the pop-up (Image attached) below appeared.
Loaded Rosetta and TC17 (V17.0.17 - build(1917))loads and seems to 'behave' as before. It is fast, even via Rosetta. It closes 'normally', ie no crashing.
The writing has been on the wall for non-silicon apps since ~2020?
Maybe it is a marketing tactic to delay the release of an AppleSilicon version?
The wall is now here, as in the attached image.
Edited by user Tuesday, September 15, 2026 4:01:34 AM(UTC)
| Reason: Added information
Frednet attached the following image(s):
(221kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
